Author Topic: painting vs powerdercoating?  (Read 6905 times)
« on: April 09, 2011, 08:56:18 AM »
Trying to decide which way to go on my engine tin... painted or powdercoating. I know the powdercoat would likely be cleaner looking, although I've read if not done right it cracks when doing up bolts through holes. As I'm going stock on this tin, it's supposed to be a black semi-gloss, can you get that sheen with the powdercoat process?
Re: painting vs powerdercoating?
« Reply #1 on: April 09, 2011, 09:14:26 AM »
i believe you can get it glossy , and it is more durable.
this is what i'm gonna do in the near future.
« Reply #2 on: April 09, 2011, 09:39:44 AM »
Powdercoat for sure! Definitely far more durable then paint. Semi-gloss should be no problem, your powdercoating place will have sample chips to show you what it will look like. Anyone who's had cracking around the bolt holes hasn't had their coating done correctly, when cured correctly it's semi-flexible just like a paint job.
Offline Chris W
  • Portland Oregon
« Reply #3 on: April 09, 2011, 09:56:32 AM »
Go with powder coating! This was done about 4 years ago.
« Reply #4 on: April 09, 2011, 06:36:19 PM »
Talk with Russ, He can hook you up with whatever you need. Powdercoating is much more durable.
Offline StubbornMule
  • www.stubbornmule.ca Wicked Coffee
    • Fresh Roasted Coffee
« Reply #5 on: April 19, 2011, 09:17:01 PM »
 iagree
Powdercoating done properly is the best way to go.  The reason for the cracking is becasue the tin wasn't hot enough when they cured it.  Be sure to get the tin sandblasted which will give wicked adhesion.   All colours are available gloss black, semigloss black etc.  Semi gloss won't show as many imperfections in the metal.  My brother has a powdercoating shop in Mission. It's Westcoast Metal Finishers and they also do sandblasting. (sorry for the shameless plug).
604-820-4516
