Author Topic: Gas Tank Rebuild  (Read 15744 times)
Offline Thomas
Gas Tank Rebuild
« on: April 01, 2011, 08:17:25 AM »
Looking for a good place to get my gas tank cleaned and lined. Any leads would be great. Thanks Thomas
Re: Gas Tank Rebuild
« Reply #1 on: April 01, 2011, 09:07:09 AM »
Here is a POR-15 kit on cl if you are interested in diy:
http://vancouver.en.craigslist.ca/rds/pts/2298631776.html
Offline Thomas
« Reply #2 on: April 01, 2011, 10:03:04 AM »
Has anyone used one of these before.
« Reply #3 on: April 01, 2011, 10:16:05 AM »
I have, but not on a VW tank.
What problem are you trying to solve? Flaking paint and surface scale inside...pretty good option. Heavy rust, not so much.  I like to remove the scale/rust that's in the tank with a length of chain and some cleaning solution before using the marine clean.
Offline Thomas
« Reply #4 on: April 01, 2011, 10:17:57 AM »
It's a rusty build up in the tank I'm trying to clean up.
Offline Jord63
  • Jordan Woodley
« Reply #5 on: April 01, 2011, 05:11:02 PM »
Check out leakers in Aldergrove. http://www.leakersgastanks.com/home.html We have used them lots here at the shop. He used to be in Langley and now works out of his house in Aldergrove and is semi-retired. He just did a pair of Mini Coopper S tanks for us at the end of last year. They were pretty bad and they turned out like new.
Offline billybob57
« Reply #6 on: May 09, 2011, 08:09:53 PM »
Does anyone know how much it should cost to reseal a Vw Bus GasTank?????
Offline number3
  • Rob Frose
    • http://www.avrparts.com
« Reply #7 on: May 09, 2011, 09:37:43 PM »
I used Leakers in Aldergrove on a tank.  Tank was rusted badly and even had a few rust through areas.  Did an excellent job.
If memory serves my tank cost about $275.00 to get it fixed.
Offline Thomas
« Reply #8 on: May 09, 2011, 09:48:19 PM »
Cost me $280 at leakers. Great job and a nice guy to deal with.
Offline Darren Dilley
« Reply #9 on: May 09, 2011, 09:50:15 PM »
i used Leakers in alidergrove too on my oval... great job would use them again.. he works out of the back of his house
 Leakers Gas Tank Renew Inc.
2231 - 264th Street
Langley  British Columbia
     V4W 2L5
Phone:    604-626-4558
Fax:         604-626-4559
Email: leaky2@shaw.ca
Offline billybob57
« Reply #10 on: May 09, 2011, 09:53:43 PM »
I was thinking when he said $200. that i was getting ripped off but i guess im gettin a Deal...
But then again my tank was only rusty on the inside....good to know what prices are out there....thanks everyone  ;)
Offline dawerks
« Reply #11 on: May 09, 2011, 09:58:26 PM »
I went to Ukranian tire and bought 2 liters of Evaporust.  Put it in the tank, shook it around, let it sit overnight, moved it around etc.  Emptied it out.  TA DA!
Like new tank for $20.
Offline beetlemania
« Reply #12 on: May 10, 2011, 09:20:17 AM »
i need to do this to my tank aswell, what did you re-seal it with after? i was told to use "SuperClean", it cleaned my tank out good, but there is still small amounts of rusty spots here and there.....
Offline dawerks
« Reply #13 on: May 10, 2011, 11:06:10 AM »
I am not 100% positive, but VW didn't 'seal' or treat their tanks at all.  Once the rust is cleaned up, and the tank is clean, I plan to put a few extra filters and run it.  Then just change the filters and it should be good to go.
« Reply #14 on: May 10, 2011, 06:53:13 PM »
I just ran a bike chain and some gas around in mine a couple times and put a filter right off the tank. Probably asking for trouble though.
Offline dawerks
« Reply #15 on: May 10, 2011, 07:14:33 PM »
Oh, the fuel tap has a small (clean) filter as well.  I ran it 'clean' 4-5 times so that should be more than good enough.  If the idle suddenly dies on the engine, then I know to pull the carb and clean it :)
