Author Topic: Interesting concept spun from an ACVW motor  (Read 2268 times)
Re: Interesting concept spun from an ACVW motor
« Reply #1 on: February 08, 2011, 04:59:27 PM »
Very cool! I'm going to start making some custom manifolds to fit ida's lol
Offline berliner
« Reply #2 on: February 08, 2011, 05:03:36 PM »
It's all fun und games til der giggly pin comes loose
Offline blarneyman
« Reply #3 on: February 08, 2011, 05:06:36 PM »
Would be pretty cool to pump out 300+hp out of a 2 cylinder engine in the back end of a bug.  :evil1:
www.mbvv.org
My \"new\" 1970 Ghia
Offline berliner
« Reply #4 on: February 08, 2011, 05:30:18 PM »
A ship I worked on many moons ago had opposed piston engines(horizontal crankshaft on top,horizontal crankshaft at the bottom,joined together with a vertical shaft driven by bevel gears.Each cylinder(10 I think)had top piston and bottom piston fighting over the same hole.Supercharger fed the air into ports opened and closed by the bottom piston,blowing exhaust out ports opened and closed by the top piston.Cranks were slightly out of sync,lower end leading,I think.Pistons met in the middle,fuel injected,boom.Two cycle operation,and they were FILTHY inside with lots of interesting things coming out the stack up top. No white dresses on deck,please.I'd like to see this new engine running,and see what kind of ooomph it will produce.
Offline iceneweb
« Reply #5 on: February 08, 2011, 09:36:05 PM »
I used to drive and fix tanks in the British Army that used engines with the same layout, but 6 cylinders on the main engines and 3 on the auxiliary engines. The sound was incredible, with 19 litres of 2 stroke diesel screaming away:
http://www.youtube.com/watch?v=lSEBG36oubg
1971 Westfalia Campmobile
