Author Topic: Wtb,Dec 58 engine case  (Read 1459 times)
Offline vwguy
« on: January 17, 2011, 07:54:58 PM »
Wtb , Dec 1958  or very close 36 hp case ( no repairs or water damage please ) . also looking for a crank  inner tin for bus. I will be at the swap this weekend.
    Jimmy D
Re: Wtb,Dec 58 engine case
« Reply #1 on: January 17, 2011, 08:52:36 PM »
Any clues as to the number range we should be looking for or are you going to make us look it up? It'll cost extra if I have to do the research too ;D
Offline vwguy
« Reply #2 on: January 17, 2011, 09:35:14 PM »
Well, I cant get to crazy here, if I can find anything from 2624613-2881524 I would be pretty Happy.
   Jimmy
Offline 72vwtype2
  • Phil
« Reply #3 on: January 18, 2011, 09:09:39 AM »
Hi Jimmy,
This should be the correct case:
http://www.thesamba.com/vw/classifieds/detail.php?id=972466
I believe the type 1 & 2 cases were the same.
1972 Kombi
1964 Vespa 150
« Reply #4 on: January 18, 2011, 10:23:50 AM »
I have a short block engine not taken apart yet   2713934   17-12-18.
no heads,   engine was  left in the rain though with no heads on, pistons rusted to barrels.   oil cooler, flywheel front pulley included, engine case not split, so all insides are still there
$60.00.
I live in Sicamous BC and will take paypal.   Would probably weigh about 120 pounds after boxed up in plywood so you can figure out shipping. Or have somebody pick it up on the way through to Calgary.  I will be in Kamloops weekend of 29 January if that helps.
Offline rustybus
« Reply #5 on: January 18, 2011, 10:39:58 AM »
My brother inlaw is coming down from kamloops on the 11th of febuary =)
Offline vwguy
« Reply #6 on: January 18, 2011, 11:58:50 AM »
Thanks for the help guy,s, I am going to follow up with Phil,s lead, if It wont work I will contact you Kev.
   Regards Jimmy D
Offline mizovalgrl
« Reply #7 on: January 18, 2011, 12:03:52 PM »
   Regards Jimmy D
Jimmy I will be in Kamloop's the last weekend in Jan as well if you need it P/U.
