Technical
Transmission Forum
What is it?
Topic: What is it? (Read 6175 times)
Dan
Crown Royal straight up....Thanks
What is it?
December 28, 2010, 06:13:26 AM »
1960 pan.....Trannie numbers read-113 301 102B.Thanks Dan
We are Bigfun
72vwtype2
Phil
Still searching....1972 Single or Double Cab
Re: What is it?
December 28, 2010, 08:55:41 AM »
The number you have posted is the tranny case part number, not the tranny number. The tranny number can be found stamped on a flat spot closer to the front and almost underneath the tranny. Once you find that number use the following table to determine the year of your tranny:
http://www.thesamba.com/vw/archives/info/bugchassisdating.php
Good luck
1972 Kombi
1964 Vespa 150
Dan
Re: What is it?
December 28, 2010, 09:28:43 AM »
We are Bigfun
Technical
Transmission Forum
What is it?
