Author Topic: axel nut removal tool needed  (Read 10256 times)
Offline stu817
« on: December 09, 2010, 05:09:02 PM »
need to remove axel nut my impact wont move it
Offline 66DB
Re: axel nut removal tool needed
« Reply #1 on: December 09, 2010, 09:26:26 PM »
Hey Stu,
Not sure if this helps or not but to crack the ones on my buggy loose I took it over to Kal Tire by my house while it was on the trailer and they had to hit it with the largest impact wrench they had to break them loose...
But I guess the car might be in pieces at the shop...if you want to borrow the trailer you're more than welcome, just let me know and I'll pull the lock off it.
Maybe a local shop will let you borrow one? Better yet hopefully someone on here has a torque master you can use...
Ed
« Reply #2 on: December 10, 2010, 09:23:49 AM »
what size is your axle nut? 36mm or 46mm
Offline stu817
« Reply #3 on: December 16, 2010, 06:12:38 PM »
36mm
Offline ovalvert
« Reply #4 on: December 23, 2010, 04:50:05 PM »
I've never liked to reuse some old axle nut that's been overtorqued and sat for 20 years anyway, so just use a grinder on both sides until you get close to the axle threads.  The nut will come off like butter and it takes about two minutes to do both sides.  Get a new nut and voila. Hope this helps
Offline notchback
« Reply #5 on: December 23, 2010, 05:48:46 PM »
I have a tool for rent if you like
Bruce McCrindle
AIRCOOLED WERKS
6047245576
New phone number above
