Author Topic: New toy  (Read 12195 times)
Offline pudge
New toy
« on: September 23, 2010, 10:40:04 AM »
Hi, my name is Paul and I have picked up a new to me bug.
It is a 74 non-super Beetle. It was bought at auction, restored to driving condition, drivin a few months and parked in a garage since 1989, and here we are.
Offline pudge
Re: New toy
« Reply #1 on: September 23, 2010, 10:41:06 AM »
Offline pudge
Re: New toy
« Reply #2 on: September 23, 2010, 10:43:46 AM »
So I spun it by hand to make sure it wasn't seized, turned nice. So I lubed the cylinders, put the plugs back in and tried jump starting it. It was getting no fuel, so pulled the tank and it was NASTY!! Off to get a new tank (thanks AVR) put that in, and try again.....now it won't even turn over, not with a jump start, not with a new battery??? Any suggestions?
Paul
Re: New toy
« Reply #3 on: September 23, 2010, 11:19:27 AM »
did you check your ignition switch connection? maybe you pulled something when you were swapping your fuel tanks
Re: New toy
« Reply #4 on: September 23, 2010, 03:15:33 PM »
Wow! a time capsule from the 80's :O0:
You may also want to have a really good look under the cooling tin for rodent nests before you get too far in to it. If the gas was bad you'll also want to change all the fuel lines now.
Re: New toy
« Reply #5 on: September 23, 2010, 05:46:25 PM »
Check the wire at the solinoid on the starter.. I've had a few cars that it's fallen off.
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
Re: New toy
« Reply #6 on: September 23, 2010, 06:26:24 PM »
That is awesome! If it were mine I'd feather my hair, slip on some high tops and and an acid-wash jean jacket and roll around just to see the looks on peoples faces.
Can you still get Vuarnet sunglasses?
Jason Hamilton
Re: New toy
« Reply #7 on: September 23, 2010, 06:29:59 PM »
soooooo choice.
Offline pudge
Re: New toy
« Reply #8 on: September 24, 2010, 07:36:06 AM »
Thanks for the tips, I will be messing with it a little more this weekend as time (haha what's that) permits. I intend on changing all the fuel lines, and going through car from one end to the other, but I want to get it running, and go from there. This thing is a real time piece, right down to the etched glass, that's right etched glass ;D Seems to be in pretty nice shape, although now that it is parked in my driveway on a slope, I have some water gathering near the gas pedal, so I will need to address that. As for rodents, etc... doubt I will find much of that as it was in my dad's buddy's workshop garage that was heated and quite clean, not that that means much, but I'm pretty sure there is nothing there, haven't any signs of anything yet anyways.
keep ya posted
P :O0:
Re: New toy
« Reply #9 on: September 27, 2010, 09:56:45 AM »
I would so roll on that, good score!!
Re: New toy
« Reply #10 on: September 27, 2010, 02:10:52 PM »
10 year old me would have KILLED to own that car.
outside of the fog lamps up front, its 100% VW Trends in '89 :)
Offline pudge
Re: New toy
« Reply #11 on: September 27, 2010, 03:25:57 PM »
Well, as it sits I can't find any wires that are not connected, and it still won't turn over.......will keep you posted...still following wires. I really think it will be something totally stupid, as it should just be a dissconnected wire. I moved my gas heater to remove my fuel tank and just layed it accross the top behind the dash (where all the wires are) so I'm sure it must have to do with that...we'll see. Other than that, nothing has been touched, and it turned over before the fuel tank was removed  wtf
Paul
Re: New toy
« Reply #12 on: September 27, 2010, 09:08:35 PM »
Do up the seatbelt, then crank it over.
« Last Edit: September 27, 2010, 09:33:58 PM by Bruce »
Re: New toy
« Reply #13 on: September 27, 2010, 09:33:52 PM »
Do up the seatbelt, then try cranking.
 I was going to say the same thing....damn late model ignition cut offs
Offline pudge
Re: New toy
« Reply #14 on: September 28, 2010, 07:37:34 AM »
oh god if that does it...I think I will snap, lol. I will try tonight, thanks for the tip.
cheers You_Rock_Emoticon
Offline pudge
Re: New toy
« Reply #15 on: October 08, 2010, 03:12:22 PM »
Well good news bad news again.....the seat belts done up and it will turn over. Not only will it turn over, but with gas in teh carb it runs!! Only problem is, I had thought I could blow air through the gas line from the tank.....wrong....plugged line....back at it I guess, but it's getting close
paul
ps, thanks for the seat belt tip
