Technical
Brakes Forum
Ercos and disk brakes
Topic: Ercos and disk brakes (Read 9872 times)
Chris
Car.
May 04, 2010, 05:48:28 PM »
So I got me some porsche bolt pattern ercos and I currently run some standard disk brakes up front and have had to do the usual clearancing and the caliper and add a spacer to prevent rub on the inside of the wheel....
What I want to know is what disk brake setups I can use that are smaller in diameter so I can eliminate the spacers.
70's Looker
More than a 70's Hooker!
what's this for?
Re: Ercos and disk brakes
May 04, 2010, 10:23:15 PM »
eh dude i got zero clue about brakes talk to lanner at vdub engineering (drunk again so check the spelling) he hooked me up with mine and im sure he can steer ya in the right direction
Bruce
May 05, 2010, 05:11:10 PM »
What "standard disc brakes" do you have? What calipers?
By far, the #1 variable in fit is the caliper. Varga, ATE, Girling all fit differently.
Chris
Car.
May 06, 2010, 12:41:41 AM »
I believe they are varga, they certainly arent stamped with anything..... what caliper has the lowest profile and will fit on the on the drop spindle mounts?
Geoff
May 06, 2010, 07:58:10 AM »
To make mine clear (with another combo) I took a old caliper and drilled test holes to see how thick it was in areas, Then I clearanced them to fit with a grinder and sander.
Chris
Car.
May 07, 2010, 04:01:39 PM »
In that case were you able to run without an adapter?
Bruce
May 07, 2010, 09:24:20 PM »
What's this adaptor you talk about? Pic?
Chris
Car.
Reply #7 on:
May 07, 2010, 09:55:21 PM »
sorry spacer, no pic for you.
josh
Reply #8 on:
May 08, 2010, 09:16:40 PM »
my ercos fit over the Jamar wide 5's I will be running with shitloads of clearance......I was surprised. my rims are not the "bubble fronts" like you have tho
Chris
Car.
Reply #9 on:
May 08, 2010, 11:25:58 PM »
ya it seems that its an issue only with the bubble fronts.....
Technical
Brakes Forum
