Author Topic: Engine sitting for a few years?  (Read 6138 times)
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« on: December 06, 2009, 08:27:33 PM »
Is there anything that should be done too an engine that has been sitting for a few years before I try and start it?  Its a type IV, 1.7, thanks jeff
Re: Engine sitting for a few years?
« Reply #1 on: December 07, 2009, 06:05:45 AM »
If it's still in the bus change the fuel lines. Regardless of where it is remove the tin over the cylinders and clean out the mouse nests, also retrieve the spare spark plugs and plug socket sitting ontop of cyl #3 ;). Put a spoonfull of oil into each cylinder and prime the oil system through the sender hole with a small funnel.
If you are happy with the way it runs you'll want to change the front and rear crank seals, the pushrod seals, the gasket under the oil filter adaptor and the O ring on the oil pump. Peening around the oil gallery plugs is a good idea too.
Offline somevwguy
  • Jeff
    • strictlygerman.ca
« Reply #2 on: December 07, 2009, 11:03:45 AM »
It
Offline kris urban
  • my beautiful baja bug that gets things done
« Reply #3 on: May 06, 2011, 01:41:57 PM »
i would adjust the valves make sure the gap is perfect of you can rick smashit one into the piston and that sucks!
« Reply #4 on: May 06, 2011, 02:03:43 PM »
You realize you're resurrecting threads from 2009?
Offline kris urban
« Reply #5 on: June 10, 2011, 08:09:29 PM »
dude all questions will not go un answered...
