Author Topic: April/6/04  (Read 12816 times)
April/6/04
« on: April 06, 2004, 01:38:51 PM »
Well it has been a long time since any updates.
In the past few months I havent had a lot of time to work on the bus but things are taking shape.
The Porsche 915 Trans was sent out to Targa Performance for Mike and the guys to work their magic. If you ever need any service work on your Porsche these guys do great work!
The trans needed, Gasket set, Two Syncro hubs,Shifter shat (this was broken when the wrecking yard guys removed it) and some other small parts. Synthetic trans fluid was also added.
(pic to be posted)
Russ from \"Frances Andrew Site Furnishing LTD\" took care of Powder coating the front bumper and brackets (and will also be doing mush more) If you need some work done give him a call 604-888-3712
(pic to be posted)
The rear brake, bearing assembly from a 74-79 bus has been cleaned and rebuilt, These will be used to make the 16x8 rear wheels fit inside the fender.
before & after pic to be posted
The rear spring plates now allow for more of a drop as they have been modified not to contact the torsion housing.
The 911 cooling fan has been sanded, wet sanded and polished......Long job and it's not finished yet!
The Pass side lower rocker under the sliding door was replaces, This finished off the welding that needed to be done. The bus is now solid!!!
Next stop was Matt (AutoMattic autobody)
The bus was droped off last weekend so Matt could get back on the job.
Here are a few pics of Matt at work blocking the body.
image to be posted
image to be posted
Also Matt welded up a few holes that were in the roof, from what ?? we have no idea.
Pic to be posted
The updates should continue at a reg rate again in hopes of a finished date in Aug?!?!?!? :o
