Author Topic: Trade My Lp 2" Narrowed Cb Beam For Your 2" Bj One  (Read 981 times)
Offline westcoast-paul
« on: April 09, 2008, 09:07:36 AM »
i have this one sitting around my shop from a past project.
Totally stripped to bare metal, CB Beam with needle bearings and Puma adjusters, CB torsion bars, new seals, new grub screws / nuts, bare metal trailing arms (4), stock carriers, stock spindles (not mounted).  Needs new link and king pins (or use your spindles).
I have a Ball Joint-based project now and would like to see if someone has a setup to swap that is maybe in the same boat as me.
drop me a note if interested.  Thanks.
« Reply #1 on: April 09, 2008, 12:07:35 PM »
still got that stock width one if you want to narrow it, even have a new set of needle bearings to put in after you're done
« Reply #2 on: April 09, 2008, 01:14:48 PM »
thanks Josh.  I currently already have a stock width adjustable in the project.  It's just i have no need for the LP one and would be easy / fast to swap a full assemble.
« Reply #3 on: April 09, 2008, 07:54:18 PM »
gotcha
