New in the Box
Scat performance I Beam connecting rods.
5.500 rod length $150
New Mahle Rod Bearings Chev
$10.00
Web Cam
Type 1, #121-125 108' lobe center
Torque monster with a great powerband ... will produce more torque at a slightly lower rpm than a reg 121.
Use with stock rockers. made on ES12 blank
$ 75.00
5" Pro comp monster tach with memory SOLD$50.00
Used Berg Pulley GB 442E
Power size, 7-1/2 lb. steel pulley, groove cut for fan belt. Dynamically Balanced. SW 9# Originated by Gene Berg in 1975. Made in USA by Gene Berg Ent
$100
Rebuilt T4 oil cooler 021-117-021-rb
to replace smaller stock T1 Cooler
$40.00
Oil Thermostat
In line thermostat, allows engine to warm up then opens and runs thru remote cooler
$20.00
Bugpack Case Savers
12x8mm 16 pcs new in package $10.00
New Premium Quality T1 lifters
Set of 8
$25.00
New set Hardened Valve Keepers
$6.00
Crane Cams Chev Valve spring retainers(for use in VW)
Set of 8
$30.00
Slightly used (100 miles)
Melling super duty Iron Oil pump
$30.00
Crank Racer spacer
$5.00
New Bosch blue coil, Painted black. 20min run time
$10.00
