Author Topic: Lot's Of Parts For Sale  (Read 1111 times)
« on: March 28, 2008, 03:07:30 PM »
New in the Box
Scat performance I Beam connecting rods.
5.500 rod length      $150
New Mahle Rod Bearings Chev
$10.00
Web Cam
Type 1,  #121-125   108' lobe center
Torque monster with a great powerband ... will produce more torque at a slightly lower rpm than a reg 121.
Use with stock rockers. made on ES12 blank
$ 75.00
5" Pro comp monster tach with memory SOLD$50.00
Used Berg Pulley  GB 442E
 Power size, 7-1/2 lb. steel pulley, groove cut for fan belt. Dynamically Balanced. SW 9# Originated by Gene Berg in 1975. Made in USA by Gene Berg Ent
$100
Rebuilt T4 oil cooler 021-117-021-rb
to replace smaller stock T1 Cooler
$40.00
Oil Thermostat
In line thermostat, allows engine to warm up then opens and runs thru remote cooler
$20.00
Bugpack Case Savers
12x8mm 16 pcs new in package $10.00
New Premium Quality T1 lifters
Set of 8
 $25.00
New set Hardened Valve Keepers
$6.00
Crane Cams Chev Valve spring retainers(for use in VW)
Set of 8
$30.00
Slightly used (100 miles)
Melling super duty Iron Oil pump
$30.00
Crank Racer spacer
$5.00
New Bosch blue coil, Painted black. 20min run time
$10.00
« Last Edit: March 28, 2008, 04:10:07 PM by Geoff »
« Reply #1 on: March 30, 2008, 04:34:50 PM »
I have a bunch more stuff to list, if you need anything... try me
« Reply #2 on: April 06, 2008, 07:20:26 PM »
ttt
