Author Topic: Roll Cage Builders  (Read 8220 times)
Roll Cage Builders
« on: February 09, 2008, 06:11:00 PM »
I am planning to have a roll cage built for my car this year and was wondering who people have used and what options you would include in your cage design.
Roll Cage Builders
« Reply #1 on: February 09, 2008, 08:03:14 PM »
CHIEF CHASSIS.
worked very well with me , the customer.
i had many detailed items i needed done and the chief made sure it was exactly as i had requested.
eg . when viewing my car from the side, the main hoop is hidden by the b pillers as well as the 2 rear tubes are tucked up from vission through the rear quarter windows,stealth was important to me.in a race application hiding the main hoop is not a worry and for the rear braces straight pipes would be used,this of course saves money as well.wanted cage attached to shell only and not the pan .when you get the drop links made make sure you have at least a dummy motor in with at least the 2 rear j tubes installed so he can position the drop links to clear .had the frt seats in the position you drive it in plus back a bit so the cross bar can be fit correctly ,and any good cage builder will make sure you are there in the car to make sure the side bars are in the correct spot relating to your body and arms as well as the rest of the cage clearances.
build it to crash so you can walk away.
race season is coming
Roll Cage Builders
« Reply #2 on: February 09, 2008, 10:08:14 PM »
Chris, go talk to Doug at Douglas chassis. They did my Fiat and they are just up the road from ya.
unit 101, 19373 Enterprise way.
604 534 0818.
Im sure Chief Chassis is good as well, but you might as well shop around.
Roll Cage Builders
« Reply #3 on: February 09, 2008, 10:56:27 PM »
Thanks Brian, can you PM and let me know what yours cost, thanks.
Roll Cage Builders
« Reply #4 on: February 10, 2008, 08:04:39 AM »
I've talked to Doug and he will be doing mine...
Offline RickyG
Re: Roll Cage Builders
« Reply #5 on: June 22, 2010, 01:20:51 PM »
how much will it cost to cage a bug up?
« Reply #6 on: June 22, 2010, 05:35:49 PM »
I paid $1300 to get mine done in my Fiat. Cant see it being more but that was 4 years ago. Call Doug at Douglas chassis, tell him Brian sent ya.
