Author Topic: Installed Drag Bar Late Model  (Read 10413 times)
« on: February 28, 2004, 10:14:23 PM »
Pictures of the Airspeed Drag Bar installed in my 1966 Beetle
Area to be trimmed
Area after initial trim
Look at the actual area needed to be trimmed - I have a feeling my car may have been hit in the rear before...
Down Bar angle
Driver's side down bar angle
Rear view
Offline Mike Scott
« Reply #1 on: February 29, 2004, 09:44:37 AM »
Nice tranny mounting bolts  :D
« Reply #2 on: February 29, 2004, 11:09:59 AM »
Ya ya ya  ;)
Offline Mike Scott
« Reply #3 on: February 29, 2004, 11:21:57 AM »
Hey James,
While were on the topic. I was wondering the pros and cons of the hard tranny mount. Is it as simple as the hard tranny mount is stronger, but decreases driver comfort a little?
« Reply #4 on: February 29, 2004, 02:52:36 PM »
If anyone needs one of those solid rear trans mounts like in James' pic, I have one for $20.
James, you should put some safety lockwire on the throw out bearing clips.  Even though you have the Saab \"hi perf\" ones, they do come out.  I've had those come out on a totally stock car.  Tie your wire through the loop of the clip, then wrap it around the bottom of the TO bearing and through the loop of the other clip.
Man, the things you swing axle guys have to put up with!
« Reply #5 on: February 29, 2004, 03:48:05 PM »
What kind of wire should I use Bruce? As far as the hard mount, I wanted one to tie in the Drag Bar - the stock one felt kinda flimsy compared to it.
« Reply #6 on: March 27, 2004, 12:18:11 PM »
bump
« Reply #7 on: March 30, 2004, 10:52:02 AM »
Dirty, Dirty, Dirty car!!! ^_^
« Reply #8 on: March 30, 2004, 02:28:07 PM »
No worries Brian, even with the weight of the dirt I'll still whoop your ass.
« Last Edit: March 30, 2004, 04:10:58 PM by James Buchan »
« Reply #9 on: March 30, 2004, 02:50:14 PM »
I cant wait James. Those ports look mighty small though. ;)
« Reply #10 on: March 30, 2004, 03:04:24 PM »
Chrome and glossy paint don't get you home..
Then maybe I'm going down the entirely wrong path :lol:
« Reply #11 on: March 30, 2004, 04:12:16 PM »
Don't tell me you under the impression that you need large ports to go fast?!!??!?! I'd have no bottom end if they were overkill large!
« Reply #12 on: March 30, 2004, 04:52:16 PM »
No I'm juust saying chrome and glossy paint won't get you home.
Meanwhile I'm making my bug look nice but I won't have major power to put a certain vert ghia in its place. oh well. At least I'll win 1600cc class.
-Kirin
« Reply #13 on: March 31, 2004, 03:17:57 PM »
I've got a spool of .030\" stainless steel lockwire.  If you can come up with something similar it should be fine.
« Reply #14 on: March 31, 2004, 03:22:58 PM »
Hopefully, you dont try to use the wire your always tugging on James!  As for no bottom end I thought you would try to get as much out of those heads as possible. Is the rummor not true that headwork is were you get most of your power from? :unsure:
« Reply #15 on: March 31, 2004, 03:59:16 PM »
Oh they have been worked, just saying on my smaller displacement and larger port would be counter productive.
Thanks for the Info Bruce, I have access to the same wire.
