Author Topic: Distributor  (Read 5762 times)
Offline 696969vw
Distributor
« on: November 23, 2007, 09:05:14 AM »
I have a D/P 1600 motor with the distributor spun 180 deg the wrong way(#1 mark is facing fan shroud). It works but I would like to set it up properly. How do I change it ?
Many thanks,
Mark.
Offline shovel80
Distributor
« Reply #1 on: November 23, 2007, 10:26:30 AM »
set #1 to TDC pull the dist look at the dist drive gear jam a pencil into the hole that the spring is in (remove spring first)
pull up on the pencil while rotating it CCW it should come up to the top of the oil hole  rotate it 180 deg and reinstall  the slot should be aprox 90 deg to the split case marks when done
Re install the dist  and should be good to go
Never ride faster than your guardian angel can fly.
Offline 696969vw
Distributor
« Reply #2 on: November 23, 2007, 10:41:40 AM »
CCW?
Offline shovel80
Distributor
« Reply #3 on: November 23, 2007, 11:37:02 AM »
counter clock wise
Offline 696969vw
Distributor
« Reply #4 on: November 23, 2007, 12:16:04 PM »
(stupid me! )Thanks.
Offline bochintz
Distributor
« Reply #5 on: November 23, 2007, 04:32:42 PM »
don't forget to put the wires correct.
CCW from the little mark on the dist rim with the cap off 1 2 3 4.
Offline shovel80
Distributor
« Reply #6 on: November 23, 2007, 06:23:42 PM »
This is what you need to rotate 180 deg
ps     Use a unsharpened pencil and taper it just a bit tap in in with a hammer and it should move
« Last Edit: November 23, 2007, 06:26:00 PM by shovel80 »
Distributor
« Reply #7 on: November 23, 2007, 11:19:17 PM »
Better than that, I suggest you install it in the orientation VW specifies.  That way if you swap in a distributor that was timed on another engine, it will at least run right away.
Turn the engine over to TDC of #1.  Remove the drive gear and re-install it so that the slot is parallel to the pulley face, and offset to the rear of the car.
