As promised...Here is the reply e-mail from my brother on this issue.
  As requested.. this is my 44IDF Settings:
The symbol
? means I Don't know or  that is just what the book tells me it's supposed to be--but I don't know as everything else is so F/K'd up!!!  ]
 Origional Settings (From **DELETED** Supplier)
 Origional Settings (From **DELETED** Supplier) Venturi   Main Gas  Main Acc.   Em-Tube  Idle Jet  Pump Jet  Aux vent  StarterJet
  32             130         135              F7           55          35            4.5
?        90F5
? Settings Now Venturi   Main Gas  Main Acc.   Em-Tube  Idle Jet  Pump Jet  Aux vent  StarterJet
   32       140-150     160               F11         60           35           4.5?        90F5
? As Far as the Weber Manual states for a 1776cc motor... Venturi   Main Gas  Main Acc.   Em-Tube  Idle Jet  Pump Jet  Aux vent  StarterJet
   36           160          165             F11          65          80
?              ?     Ultimately I don't have any references to go from except the Weber book I have and I don't know if I trust it either??
    FYI Engine Stats:
    Engine is a 1776 cc motor in an AE case(virgin-not cut)
    I'm running a Scatt 69mm counterweight crank (VW journals)
    Engle 110 cam- (Upgrading right away to an Engle 120 cam
    big foot lifters, elephant bearings, stock pushrod tubes
    90.5 Mahle/Cima pistons, 40x35.5 heads- open portes,SS valves, High rev
    Single valve springs, Hardened Keepers,
    9:1 Compression Ratio
    Stock rocker ratio 1:1 w/ solid shafts and swivel foot adjusters
    Heavy duty oil pump W/ remote oil filter
    lightened flywheel (13lbs)  1700lb Kennedy pressure plate
    4 into 1 header W/ duel quiet packs ( big Triangle flange) -j tubes
    009 Distributer ( California) W/ Purlux Ignitor
    Currently running  Weber 34 ICT Dual Carbs
There it is folks...
Hope you can help..
 - Doug
