Technical
Electronics & Car Audio Forum
Tach Light On When Switch Is Not On
Topic: Tach Light On When Switch Is Not On (Read 7492 times)
egspot
October 21, 2007, 05:58:35 PM »
So I installed the tachometer and it is working:
Cables:
Black= Ground
Red=power 12V
Green= negative terminal on the coil
White- light for the tach. On my old 64 there was a conection with the lights power and it worked great. on the pictures below, I can't find a sourse and the left 1st and 2nd both suply continues power. Anyone wants to point me in the right direction?
http://www.cardomain.com/ride/2142087
dannyboy
October 21, 2007, 11:26:35 PM »
find out which prong on the headlight switch is for the dash lights, and connect it there...
i looked on vintagebus.com wiring diagrams, and the prong should be labeled 58b i think (check for yourself to make sure you have the same switch...
egspot
October 22, 2007, 05:45:23 AM »
Thanks Danny.
GMB
October 24, 2007, 02:22:02 PM »
Or piggy back off one of the dash lights!
Warrior sand rail:
2276cc 82x94
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
egspot
October 24, 2007, 10:20:32 PM »
Does that mean I spliced them toguether?
Can i look and find a part that would do it?
Last Edit: October 24, 2007, 10:21:02 PM by egspot
Technical
