Author Topic: Adjustable King/link Pin Beam  (Read 9710 times)
Offline flat4
« on: July 21, 2003, 07:57:00 PM »
This posting is also in wheels/tires.  I just installed an adjustable king/link pin beam in my 63 beetle. The car has CB drop spindles and 5.5 or 6 inch chromies with 185/55/15 tires up front( they fit BEAUTIFULLY on the wheels). The problem I'm having, is that the driver's side wheel sits between 3/4 and 1 inch OUTSIDE the fender. The passenger side fits just inside the fender.
Is this a wheel/tire problem or something else?
Any help would be GREATLY appreciated, and thanks!
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Offline thrasherbill
« Reply #1 on: July 23, 2003, 10:16:57 AM »
Does your car have aftermarket fenders? A lot of times they won't be exactly the same side to side (IE - width, fenderwell opening, headlight bucket placement, etc.)
ThrasheR
CLICK.
Pinhead Lounge
Offline Rooodie
    • http://www.dglvk.com
« Reply #2 on: July 23, 2003, 01:25:35 PM »
Is the back spacing on the two front wheels the same?
DGLVK
West Coast Show Down 2004
Offline flat4
« Reply #3 on: July 24, 2003, 06:46:08 AM »
Thanks for your replies.  The wheels are identical, and both fenders are original.  I did in fact find the problem.  I took the new beam out and did some measurements.  It turns out, that the beam is actually welded together incorrectly.  It seems as though one shock tower is out 1/8 inch at the bottom, and continued to move further outwards.  I also found that the torsion bar tubes were different lengths as well.  I put the original beam back in with the CB drop spindles, and everything lined up perfectly.
« Last Edit: July 24, 2003, 06:47:37 AM by flat4 »
Water is for ducks
Sand Rail Project
« Reply #4 on: July 24, 2003, 09:42:20 AM »
That really strange, what kind of beam is it? I've never seen that before.
Offline flat4
« Reply #5 on: July 26, 2003, 09:34:39 AM »
It is/was a brazillian beam with berg style adjusters.  It was really an odd thing to see.
Water is for ducks
Sand Rail Project
