Author Topic: 53 Right Hand Drive For Sale  (Read 2877 times)
Offline doubledoor
« on: April 11, 2007, 07:42:40 PM »
Time to sell and move on.This is not a project for the weak at heart.
It is a 53 that i converted to RHD i have most of the RHD parts. It has a four tab hood L&R semiphor front fenders repo rear fenders heart taillights with most of the parts It also has three ribbed doors and a wide spring W decklid. The pan has new pan halves and the RHD pedal work has been done. I have two swing axle trannys for it. I have low back front seats and a rear seat. It can be made a zwitter at an extra cost because i do have a split clip i would part with. The pics aren't the best because it is stored on a shelf in the corner of my shop. People interisted could come view it.
I would like to see it go to a good home and I am asking $3000.00 without the split clip. :D
« Last Edit: April 11, 2007, 07:43:53 PM by doubledoor »
49 ford coupe
Offline bugme
« Reply #1 on: April 11, 2007, 09:41:32 PM »
pm sent
Offline doubledoor
« Reply #2 on: April 15, 2007, 11:13:57 AM »
I know someone out there wants a 53' RHD zwitter :D
49 ford coupe
Offline chris wilson
  • Junior Member
Re: 53 Right Hand Drive For Sale
« Reply #3 on: June 05, 2013, 08:56:37 AM »
just inquireing? noticed your add; i am looking for a front hood for my zwitter. my car has come out of the paint shop except my hood was sand blasted  and ruined the hood. if you would consider selling your hood give me a call at 250 881 5521. thanks for your time
« Reply #4 on: June 05, 2013, 09:58:13 AM »
Chris is your messed up hood a 5 bolt? I might be interested if you are going to get rid of it...
Josh
« Reply #5 on: June 05, 2013, 10:24:41 AM »
Chris, this original post is from 2007....
Offline Herrlowlight
  • OldBusBoy
« Reply #6 on: June 06, 2013, 04:19:20 PM »
Is a '53 hood different than a 4 tab oval hood?
Trevor
1968 912
1958 Kombi
« Reply #7 on: June 06, 2013, 07:30:20 PM »
Trevor
Real early ones (split) had 3 bolts holding each hinge to the hood and a separate bolt for the prop so 7 bolts.
Can't remember year (zwitter?) went to one less bolt but kept separate hood prop....called a 5 bolt
Until 55 and they added the prop to one of the hinge bolts.
There were also a little while around 54 into 55 where there was a little triangle reinforcement under the 4 tab emblem
