Author Topic: Pic Of Hard Tranny Mount?  (Read 10486 times)
« on: January 31, 2004, 06:14:38 PM »
Anyone have a picture of their hard tranny mount (bellhousing end) with the strap going over the tranny?
I installed mine today and don't feel comfortable with where it sits - I will post a pic of it in the morning.
Thanks.
« Last Edit: February 01, 2004, 11:47:20 AM by James Buchan »
Offline notchback
« Reply #1 on: January 31, 2004, 07:21:39 PM »
Why is the header touching the drivers side of the lower mount. Mine did and I had to modify it by grinding a small piece of it off so everything worked out.
Bruce McCrindle
AIRCOOLED WERKS
6047245576
New phone number above
Offline nivag
  • Gavin Lee
« Reply #2 on: January 31, 2004, 08:44:02 PM »
I think my Berg header was hitting the driver side too. I had to grind quite a bit out. James, I will have my motor out of the oval in about a week and if you still need can take a pic then.
« Reply #3 on: January 31, 2004, 09:19:32 PM »
I was more concerned about the strap in the starter housing area - not comfortable with the way it loops over it.
« Reply #4 on: February 01, 2004, 11:47:45 AM »
Pics added above.
« Reply #5 on: February 01, 2004, 02:05:00 PM »
What is it about the strap you don't like?
Offline kombikruiser
« Reply #6 on: February 01, 2004, 04:49:57 PM »
that is the same way mine looks on my 67. its just installed a little more toward the rear of the car, about 1/8-1/4\" from being flush with the bell housing
'57 Type 1
'67 Type 1
'66 Type 2
'67 Type 3 Fastback
« Reply #7 on: February 01, 2004, 04:52:29 PM »
this is what james is not happy about, bruce.
« Reply #8 on: February 01, 2004, 07:16:59 PM »
I guess no worries then - thanks guys.
Offline notchback
« Reply #9 on: February 01, 2004, 09:28:18 PM »
I saw that, i just figured i would let him know that those mounts always interfere with  a merged header.
Bruce McCrindle
AIRCOOLED WERKS
6047245576
Offline Mike Scott
« Reply #10 on: February 19, 2004, 12:40:17 PM »
Hey James,
Im sure you already know, but might want to check if your flywheel clears those pretty new (nylon) lock nuts.
If you ever put in that motor  :unsure:
« Reply #11 on: February 19, 2004, 02:57:22 PM »
Great another thing to worry about!
« Reply #12 on: February 19, 2004, 03:35:31 PM »
Yeah, Those bolts are instaled the wrong way! better change those B)
« Reply #13 on: February 19, 2004, 04:04:03 PM »
I installed them like that on purpose  :blush:
« Reply #14 on: February 20, 2004, 01:16:10 AM »
I really don't see the need for the strap that goes over the top.  The 4 bolts at the bottom should suffice.  I've never seen a trans case busted in that area on cars without the strap.
I'd also recommend you put some safety lockwire on the clips that hold your throw-out bearing.  Tie around the loop of one clip then wrap the wire under the T-O bearing and tie to the other clip.  Those clips are notorious for falling out, even the double loop Saab type you have.
Offline Tom H.
« Reply #15 on: February 24, 2004, 08:55:12 PM »
Straps suck.
« Last Edit: February 24, 2004, 09:01:01 PM by Tom H. »
« Reply #16 on: March 27, 2004, 12:19:34 PM »
bump
