Author Topic: Need kadrons 40/44 carbs for parts  (Read 1039 times)
Offline jefftrish
« on: May 12, 2013, 04:31:16 PM »
Can be in any condition. pacifically looking for check-ball after accelerater pump. I would be interested in one carb, or whole set.
 My 69 fastback is ready for the road first time in 7 yrs. This all that is holding it back.
Regards,
Jeff
Jodasa
Re: Need kadrons 40/44 carbs for parts
« Reply #1 on: May 15, 2013, 10:57:22 AM »
For sale from Mister Kadron.
http://www.lowbugget.com/kadronparts.html
$24.99 Kadron Gasket kits. Each. Our kits are made in the USA, not the China crap
like the others!!!
The best gasket kit for the Kadron carbs. We know as we have tried  them all!
Solex/Brosol H40/44EIS Gaskets. Yes the Kadrons!
You will need 2x gasket kits for a complete set of kadrons.
Each of Our USA made gasket kits come with one replacement check ball.
( Tip )  Just adding new gaskets to your carbs will not change whats wrong.
If your motor has a broken crank would you just replace the gaskets? No, you have not
fixed the problem! We have no problem offering these kits to you but the problem
may be more than a new gasket and some carb spray!!!!
