Project Forums => Past Projects => Project Klaatu => Topic started by: Klaatu on September 14, 2005, 05:37:45 PM
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fklaatu%2F2005-10-14%2F01.jpg&hash=1f5a40d29c1df44c59d9efd5ac0bd16ebd0e5f16)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fklaatu%2F2005-10-14%2F02.jpg&hash=7bc47e26debf8c522ec8cb963ecc4360954acad0)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fklaatu%2F2005-10-14%2F03.jpg&hash=66060494b8ffc2d584f100f09b532aa4ee5c0d59)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fklaatu%2F2005-10-14%2F04.jpg&hash=a5836bda89dd48f140f309dedceb9a0b37eff9ee)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fklaatu%2F2005-10-14%2F05.jpg&hash=5a62285d45d70c36a95c03f9b2a82a711b157a6b)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fklaatu%2F2005-10-14%2F06.jpg&hash=7388c4483ad2b08213436fee099c977a491f905d)
Well its time for another update.As everyone knows things always take twice as long as you expect.
The intercooler took a lot longer than I thought to arrive so it kind of delayed things a bit. The box you see in the pictures will eventually have ice water running through it from a 4 gallon storage tank under the back seat and through a 72 pass cooler with a fan under the pass side rear of the car.The cooler drops inlet temp.by over 110 deg. which means big HP gains and no problems with detonation. The throttle body is a 70mm unit which should give more than enough inlet air and good driveability.The unit you see in the center of the engine compartment is the blow-off valve which releases pressure in the intake when u get out of the throttle.The turbo is still making boost and it has no were to go the blow-off bleeds that pressure off. The next plan is to build the intake in the engine comp. and mount the water tank and plumb it.I will try to update quicker but building everything from scratch is time consuming. TJ
sweet.. bro, look'n good ;)
Wowzers!
I wish I had those mad fabrication skills and the will, and the check book.
Can't wait to see how much crazy power this thing makes....
damn.
nice work jim. keep it up bro.
shit i just creamed my pants
You are all fu#$in nuts......Wicked bad!
You know you want one :D
I was there the other day to watch Kleetus being worked on and it almost motivated me to work on the Hulk so I went to Flossin's instead .... ;)
And got to see alot of \"First's\" Two very sweet rides in one day..... who said you had to go to California to see bad ass cars.. :rockon:
Shane's got it right, 2 bad ass cars. One's gonna have crazy power with a turbo and be a little stealth in the looks department and one's gonna have awesome power for a N/A motor with the detail work of a madman
Wow! Tight setup!
I'm curious how the charge cooler is going to get air from? (Is that right, the outside air will hit the charge cooler, then intercooler? before going into the turbo).
Nice set up, I'm assuming it's a drag only car. But for a daily driver, I think that turbo would make some good heat in the winter! :)
Jimmy's car will be fully streetable daily driver, thats why he is investing so much time into research for the parts and computer programs to run it. Its gonna be awesome, I want to do it to but putting in another 5000 into my motor is a lot.......maybe one day
well i think i got the itch... for a blow through :huh:
Go for it Darren, i know a few guys who are thinking of a winter motor change including myself
Hey,Whatever way you want to go let us know.This whole idea has got me revved up,I love doing something like this were you have to plan out every little detail because in the end it pays off huge.Some of the things that I did to the Hulk were questioned but anyone who has gone for a ride in the car will agree the power is truly nuts.I can hardly waite to see how the cars up here progress in the next few years,we have a killer group of people and some world class cars with more to come.TJ
Way to go Jim. Definitly on the wild side. Nice fabing skills, it all starts with some thoughts, trail and error, and some extra holding hands to make it fit well. This must be a business write off too...Lucky guy.
no ,no not a moto change..Bro.. a hole new car .... :o
I know your doing the new car, i just thought you were thinking turbo for it now
lanny and i are look\"n at a 67 ....
awesome
I was not going to let the cat out of the bag there Darren, I personally think the new car is way too nice for the strip... It would be a shame to let the rubber fly on that car.... So build a race car!! ;) :rockon:
Darren, kinda hard to believe but I think your going to have to add on to your garage! Just put a turbo in your wifes car. :huh:
Darrens will make 200 plus without the progressive/ pro fogger NOS set up. Pretty serious electronics for a car with carbs. It can be programmed to start the run with a 20% shot, ramping up to the full 100% where you set it. Them wheelwells are squeaky clean for now.. Yes, it's true, we found a 38K mile 67 in the US that is a starting point for a full out race car. :wacko: I'm picking it up on the Tacoma show weekend. You better bet TJ will be involved...
Jim, all those goodies look a bit big for a 1641 cc Engine,,,,,,,
( I guess I better get busy on your motor hugh )
Yes Mr. K-Roc, I am expecting delivery in 10 days! Your also correct about the 1641 so I have decided to go crazzzy and step it up to a 1835.Get on it! ;)
I called the 1835cc first TJ ]:(
Nice O holy green one!Is that were u hook the tie down to? :P
Laugh now but when your engine is in 300 pieces on the track... you too will have an extra tie down... :P
Don't forget How Kleetus got home from Seattle.. :P :P All broken like
Thanks Amanda! I don't mind breaking my trans. because I'm going to have to get used to that. Unless I.............. [_[
I think someone has been drinking the water from the intercooler?!
Yeah Yeah , Just shut up and put up a number like the rest of them....
I think you need to stop making love to the intercooler and start working on that car....
I have put up a number every time u drive the car. :lol: :lol: :lol: :lol:
Well Jim, your car is truly inspirational. If you can put all your know how to building a tranny that will hold up Ill be more impressed. All that work and all youll get is maybe 2 passes on it before you brake something. Sorry, just going by what Ive seen in the last couple of years. ;) Klaatu hasnt met the Red Snapper yet, be scared! :P
Seems to me that car should be worthy of a Mendeola. Easy for me to say since I'm not the one writing the checks!
Your car is defineatly something to watch for next year...keep up the great work Jim. :rockon:
Ok, lets all chip in and buy Shane a winter hobby. I think he is getting cabin fever without the Hulk to look forward to. :wacko:
Mendeola ,removable apron ,5pt cage ,suddenly it ain't much of a street car with the tranny raise already done .Maybe the water bucket has room to hold a couple of pops &sandwiches for those lovely 140 mph Sunday drives!
Now your thinking G-dog.. ;) I know at 130 I get pretty hungry...Could you do like a leather wrap on the top of the box?
Diamond plate look?
Jason.... I have a hobby and that is picking on you , I don't need more tham one Hobby... See Jimmy ribs me and I rib him.. That is how the game works...
Wanna try play? ;)
Wanna try play? ;)
You've met me right?? Do I seem bright enough to play a game of wits??? Gee thanks buddy! :)
Well you do live in Salmon arm.... ;) I am sorry I will try and slow it down for you :P
