Not too challenging, you'll have to carefully pry out (unclip) some of the linked together fuse clips and move them around to match the 70 box if you want to be able to use the 70 diagram and fuse layout later, and you'll need the later flasher and headlight relay. Once it's in only you will know the difference.
