Project Forums => Hot Rod Hebmuller => Topic started by: Geoff on October 26, 2004, 10:01:34 AM
Title: Update #9
Post by: Geoff on October 26, 2004, 10:01:34 AM
This past Sunday I worked on the rear cowel area and managed to get most of it sheeted over. It now looks like a Heb rear BUT there is still a ton of work to do on the fire wall, hood hinge area, rear cowel support, etc.
Last update I just started to get the cowel area mounted, here is what I started with Sunday afternoon.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_heb-rod-oct26-04-1.jpg&hash=c266a6809a74cc5b41ef7256483df97c78885606)
I started on the drivers side and worked my way to the center.
Here I just tacked the corner pannel into place. I made that by bending it over a paint can (wish I had a english wheel...and knew how to use it)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_heb-rod-oct26-04-2.jpg&hash=f2edfea047800050714fb6b5f7ff1e957cfbeca9)
same as before, a spray can and some elbow grease and the corner fits fairly well!
  (https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fheb-rod-oct26-04-3.jpg&hash=e893bb4ff963896b29ca56ae0cbbbbece7528747)
here you can see i made some templates to fill in the open space, I later used these to make my pannels.
Also  you can see the felt louvers and that thing that looks like a face, It's where the gas cap will go.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_heb-rod-oct26-04-4.jpg&hash=5aeac17760830d420b91ddafdea2a82263f1d191)
It's now starting to look more like a heb!
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_heb-rod-oct26-05.jpg&hash=e1c0144dc73993e1cb7869acef2844fe65132b34)
Here is a shot with it all filled in. Also note the Vintage filler cap. This will be most likely mounted here on the rear cowel to the tank below.
Also a set of louvers will be added to aid in cooling the motor (for now the felt marker vents will have to do ;-)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_heb-rod-oct26-04-7.jpg&hash=6a752112d267c0168ca981ccf67e0a271dc23996)
While searching for a vintage filler neck I found this period Banjo steering wheel. This wheel look close to the early Ford Banjo wheels. Very cool!
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_heb-rod-oct26-04-8.jpg&hash=3dc561e38ce6701d67b5bdc5710616dbddc7c5a6)
Thats it for this weekends work. I hope to get back to it later next week.
