Technical => Engine Tech Forum => Topic started by: Geoff on July 27, 2011, 01:56:10 PM
Here is a list of engine codes for T1 blocks, credit to thesamba.
Type 1
Code Year Engine/Notes
1- Pre-Jan., 1956 25hp/36hp
1- prefix indicates Type 1 and is not part of the sequential engine number.
2, 3, 4, 5, 6, 7, 8, 9 55-65 1200cc, 36hp/40hp
D0 1966/67 1200cc
F0 1966/67 1300cc
H0 1967 1500cc
F1 1967 40hp
E0 1967 M240 low compression 37hp
L0 1967 M240 low compression 40hp
H5 1968/69 1500cc
B6 1970 1600cc - dual relief, single port
AB 1971/73 1300cc - dual port
AE 1971/72 1600cc - dual relief, dual port
AH 1973/74 1600cc - 8mm head studs with case savers
AJ 1975-1979 1600cc - fuel injected
Type 2
20- Pre-Jan., 1956 25hp/36hp
20- prefix indicates Type 2 and is not part of the sequential engine number.
O 1963/64 1500cc - no cam bearings
H 1965 1500cc
HO 1966/67 1500cc
B5 1968/69 1600cc - single relief
B5 1970 1600cc - dual relief
AE 1971 1600cc
CB 1972/73 1700cc - dual carb., manual transmission
CD 1973 1700cc - dual carb., automatic transmission
AW 1973/74 1800cc - dual carb.
AW 1975 1800cc - fuel-injected
AP 1974/75 1800cc - European only
ED 1975 1800cc
GD 1976/77 2000cc
CJ 1976-1979 2000cc - European only
GE 1978/79 2000cc
CU 1980-1983 2000cc - Vanagon style
CV 1980-1983 2000cc - Vanagon style
Type 3
O 1961-65 1500cc
K0 1966-1972 1500cc - 54hp
M0 1966-1972 1500cc - M240 low compression 52hp
P0 1966/67 1600cc - M240 low compression 50hp
T0 1966-1973 1600cc
U0 1968-1973 1600cc - fuel injected for USA
U0 1970 1600cc - dual-relief case
U5 1971-1973 1600cc - 7.7:1 compression - US/Canada M239 California fuel-injection
X 1972 1600cc - 7.3:1 compression - California
Type 4
V 1969 1700cc - 68hp
Z 1969/70 1700cc - 7.8:1 compression - 68hp, dual carb., automatic transmission
W 1971 1700cc - 8.2:1 compression - 80hp
EA 1972-1974 1700cc
EB 1973 1700cc - California only, fuel injection
EC 1974 1800cc
AN 1974 1800cc - 8.6:1 compression
AT 1974 1800cc - European only, dual carb.
Porsche 914
W 1970/71 1700cc - 8.2:1 compression - 80hp
EA 1972-1973 1700cc
EB 1973 1700cc - 7.3: compression, California only, fuel injection
EC 1974 1800cc - California only, 7.6:1 compression
AN 1800cc - 8.6:1 compression
GA 1973/74 2000cc - 7.6:1 comporession
GB 1973-1976 2000cc - 8.0:1 compresssion
GC 1975/76 2000cc - 7.6:1 compresssion
V0 1700cc - European-only
1800cc - European-only
2000cc - European-only
Replacement cases
These cases were VW engine cases that were sold from VW but never issued in an actual production vehicle. All are dual-relief cases with 100mm oil passages.
Example:
Information from a 5/73 USA service bulletin issued 5/73:
Engines with the re-manufactured symbol, a letter, a number and ending with X, indicates a VW Exchange engine. Before Oct., 1968 the X was not stamped onto the block.
From April of 1972 Shortblocks were sold with the VW remanufacture symbol followed by a letter. No numbers were used, you were to stamp in the old engine number.
F1 1300/1600
F2 1300/1600
DO 40hp if last digit is "X"
D1 40hp part
AD 1600
AK 1967-1974 1500/1600
AM 1600
AS Sometimes seen listed as Super Beetle case for 1973-onward
Exchange engines
These engines are normally marked with a VW recycle symbol and an X at the end.
Example:
"Replacement cases
These cases were VW engine cases that were sold from VW but never issued in an actual production vehicle. All are dual-relief cases with 100mm oil passages."
100mm oil passages? Wow! That's a lot of oil space.
I know this is an old post, and my question kinda dumb, but I have an AD case. Is that a good thing?
Just wanted to add that AM cases were also factory engines for some/all 70's Things 1600 cc. I know this from several Things that were sold by our local dealer back when I was still in high school...Beetles had AH but Things had AM codes...
Found a engine in a 69" with "AK136466" stamped on block under oil filler.. What is it? The owner claims its a Porches 911??
I'm trying to buy the car but....?
914 numbers
912
911's seem much different.... Or in Geoffs first post
Sounds like a 73 beetle motor: http://www.thesamba.com/vw/archives/info/bugchassisdating.php , is it 6 cylinder, or 4?
It's a 4... And clearly a vw engine. Lots of crome on it is all.
Car has front disc brakes and is in vary good shape. Not sure what it's worth but he's asking 3900?
Sorry, not sure if this is the right place? I have an old engine 1328068, year? no prefix letters.
OOPS found it, looks like Jan,1956.
I'm trying to find out about a 36hp engine with a code I've never seen before
E-21927
anybody have any idea what year
thanks
Hank
I think I found out the answer to my 36hp year question
it might be a VW industrial engine made from June to July 1956
cheers
Hank
Another possibility is (see last comment of this Samba post)
https://www.thesamba.com/vw/forum/viewtopic.php?t=433995&highlight=engine+code
that was an interesting thesamba posting
I bought a VW powered ski hill tag line system 30 + years ago
it had a 36 hp. engine hooked up to a type 2 split case transaxle with one brake drum bolted to a solid arm on the mount.
I'm not sure if this "E" engine was the one or not that powered it- I have a few other 36 hp. engines
thanks
Hank
