General Forums => VW Club Corner => Topic started by: Tyrel on January 26, 2006, 01:18:16 PM
well this morning i was taking out the bolts that hold the pan and body together, and 4 of the ones under the car that appear to go into the heater channel wont come out. it sounds like a backing plate inside the channel is spining with the bolt? will i be able to just lift the body and hope those pull through or is there a better solution? now the heater channels must be shot so how hard is it to put new ones on??? im putting a 3\" bodt lift on this car if that makes any difference at all :P thanks guys Tyrel
Get in there with your angle grinder and grind the heads off. Don't pull them through.
