Forum Help, Suggestions & Testing Grounds > Forum Help
Problem With The Proper Times Showing? Solution.
Forum Master:
This is a setting that needs to be done to any new account so that the proper times appear in posts, etc.
1: Locate and click on the "My Controls" selection just below the forum header. (right-click and 'open in new window' if you want to keep these instructions open while performing this)
2: On the left hand side of the control panel, find and click on the "Board Settings" selection.
3: Adjust the Time Zone Selection to your time zone. Air Speed Zone is: (GMT - 8:00 hours) Pacific Time (US & Canada)
4: If it is Daylight Savings Time (April-October), make sure the the Daylight Savings Time check box is Checked.
5: Click on the "Change My Account Options" Button at the bottom of the screen and you are complete.
6: Now you should see the proper time in red (See example below). Make sure that it is correct
          Example:
                    The time (including your current adjustment) is:
                    Jun 25 2003, 01:57 PM
The times in the forum should now be correct. :lol:
