***Priced reduced, don't want to store it over the winter***
Custom built VW Beetle,1966 chassis with a 1960 body, original glass snowflake rear lights. Fully restored pan - new pan halves, new heater channels and all rust removed from body and replaced with new metal. New paint inside and out, windshield, rubber seals and moldings. New interior by TMI including door panels, seat upholstery, headliner in CDN Standard style (center section only), carpet front, rear, trunk and tire cover. New steering wheel, turn signal assembly, front and rear lap belts. Fully sorted motor and transmission- fitted with older freeway flyer tranny and heavy duty clutch and vintage sparkomatic competition shifter. Very strong AE code 1600 engine fitted with single port heads, new muffler, converted to 12V. Dual circuit master cylinder with front disc brakes and ball joint front end from European model 69 Beetle, new brake lines and hoses, new wheel cylinders and shoes. Properly lowered 2.5 inches with drop spindles. Silver 8 spoke aluminum wheels with wheel locks, and new rubber. All electrical works perfectly, runs, stops and drives great and yes, even the interior light works.
Just waiting for it's new forever home, this great little car will make someone very happy.
Only 5 minutes from airport, fly in and drive it home
