Technical => Chassis & Suspension Forum => Topic started by: WhiteDonkey on September 17, 2015, 08:44:42 PM
Hi all and thx in advance
I have a king n link front beam and the inner race for the bearing is stuck on the spindle .....I've soaked and heated.......still does not remove .....any tricks or ideas pls
Drill it then split it with a chisel
You should be able to clamp a bearing splitter into the groove between the bearing and the spindle. Then use a standard puller on the bearing splitter.
If that doesn't work, take an angle grinder and grind it at 12 O'Clock until it is super thin. Then hit it with a hammer and it should split.
If he was running late and didn't get to it until 12:30, would it still work?
