James..thats a good link...i think i'll contact that guy...the carb rebuild kits look like a good deal.
I had a look at the rebuild kits and thought that was the stupidest kit i've ever seen. For example, it includes the plug on top of the filter screen. That part never wears out, never gets damaged, and is never missing. Why make you buy it? The throttle shaft spring and pump lever spring are other items you don't need.
A couple of weeks ago I was in at Overseas Auto on Main and had a look at their kits. They are genuine Weber, with only the gaskets you need, for a lot less $. Then Overseas carries any of the other bits you may need separately. Including 42mm venturis. Talk to Jim there.
