Technical => Wheel & Tire Forum => Topic started by: neil68 on February 23, 2007, 07:58:05 PM
I'm looking at buying a pair of 5.5\" 4-bolt Centreline aluminum wheels with 4\" backspace for:
'68 Beetle
SAW short axles
stock 4 x 130 drums (snout machined for short axles)
6\" x 26\" M&H slicks
Has anyone run this combo on a late Beetle?
jim martin runs 4 bolt centerlines w/ m&h dot slicks on the back and 145's on the front. 68 chassis. not sure if he has short or long axles, and i dont know the width or backspacing of his wheels.
hopefully he'll chime in.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fimages.thesamba.com%2Fvw%2Fgallery%2Fpix%2F232074.jpg&hash=6ffd08856b6f5f136737c01f0005a1ee0a6ff088)
yes i run the exact combo you are thinking about,the backspacing will be the same as mine as there was no other options in a 5.5\" centerline rim.
as far as having 5.5\" rims on the frt i cannot help you as mine are the 3.5\" .
and the use of a 3.5\" rim may require narrowing the beam ,but if i remember they do clear.
centerlines are light and still one of the coolest racing rims made.
since they are a real 2 piece racing rim that is rivited together they were all expected to use a tube.
but for street/track use it adds weight so the centre sealing can be easily modified to allow tubless use.
my biggest concern was mounting to the car .there are a few ways to do it and mine is possibley the most positive .
this phot shows the studs and collar i made.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fmembers.shaw.ca%2Fchoptop2%2Fjimscar2%2FDCP_1114.JPG&hash=99a06dfe928e69ea60ce89304830e444bc4c1872)
if you are seriously going to buy them get in touch with me and i will cover the different mounting methods.
Thanks Jim,
Your info was exactly what I was looking for! I remember seeing your '68 at the DVKK Strip Show at Mission in August and will get ahold of you for details, once I sort out which way I'm going for wheels.
I'm trying to decide between 4-bolt Erco's, Centerlines or Sprintstars with M&H DOT's or slicks.
Neil.
