5x130 Ercos c/w washers (15x3.5, 3.25" backspace bubble fronts and 15x6, 4" backspace rears) with front runners and 26x15x6 Slicks $800
Roll CAGE, not roll bar, $750 OBO
Mexi 043 heads - 94mm 40x35.5 - New valves and springs (cb650) - 47cc - c/w valve covers and match ported IDF manifolds $850 SOLD
RLR rear torsion 3" raise kit $75
32" Ladder Bars $150 SOLD
NEW Jaycee Drag Race Oil Filler Stand, blue $40 SOLD
NEW Ron Lummus Racing 1.5 QT Breather Box $150 SOLD
NEW CB Performance #1863 - Maxi 30 Full Flow Oil Pump, blue cover. $75 OBO SOLD
NEW JayCee Billet Fuel Pump Block-off, Blue $30 SOLD
NEW Speedflo Oil Filter by Jaycee, blue. $120 SOLD
NEW WEB 86C cam and lifters $125 SOLD
Autometer #3327 2 1/16" Oil Press and #3347 2-1/16" oil temperature 100-250 °f Sport Comp guages with senders $140 SOLD
Hi-torque starter Type 1 $200 SOLD
Taylor Aluminum vented battery box, used but all good, with parts for heavy duty battery strap. $50 SOLD
Type 1 Alternator Stand $20 SOLD
Stock Oil cooler and mount $50 SOLD
AS41 Case - 94mm - Full Flowed - Case Savers - Clearanced & Decked - STD $850 SOLD
VW Stock Rods $125 SOLD
Deep Sump with drain back - 3" x 10.5" x 9.5" $100 SOLD
Full Flow Oil Pump and Remote Filter and under fender mount c/w hoses and fittings $100 SOLD
NEW MAHLE / CIMA GRAPHITE COATED 94MM X 69MM - 1914CC PISTON & CYLINDER $450 SOLD
Gene Berg Full Flow Oil Pump Cover - $30 SOLD
Empi Oil Cooler Block off $25 SOLD
CSP Oil Cooler Block off $50 SOLD
Link Pin Beam with leaves and Steering box $150 SOLD
More to come......
PM if you are looking for anything, package deals possible on any combination of items.
