Project Forums => Hot Rod Hebmuller => Topic started by: Geoff on January 10, 2006, 12:12:03 PM
Title: Update #19
Post by: Geoff on January 10, 2006, 12:12:03 PM
For this update I will cover the rear fender area and a few other small things.
First is a pic of the car that I like, Shows the longer wheelbase with the front wheels pushed out.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-24.jpg&hash=802bab31e742069f9505124d3dab3caba83a155f)
For the rear fender I have tried to cary the theme from the front arch into the rear. Once again I used oval tubing and bent it to shape. The hard part here was getting the radius the same as the tire once at ride height. I wanted aprox 2" opening around the tire, so a dummy motor was put in and ride height was set.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-20.jpg&hash=7a9eada1284a6695f67383076188ba749328ca39)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-19.jpg&hash=f81e2474cf97002a27eba731e4d8b022ccf78aeb)
I used a fender and cut it up so it would work with the new wheel arch.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-21.jpg&hash=eb2ad147ba13e001f4db82359b5937df88fa5d89)
Here you can see the opening around the tire, it then blends into the apron angle to the rear of the tire.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-22.jpg&hash=b31d90f8edc3896b4ecc093d0cdf0e59358e33db)
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-23.jpg&hash=4f8382272c97795690e682d995b67a67e525a3ca)
The front brake  vent's came in and have been installled onto the Ford brakes.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-13.jpg&hash=0e8a1b0d3266d74635af8eccedb4f822d9ac8554)
Last shot is the rear of the car with the 55 bus tail lights.
(https://airspeedparts.com/forums/proxy.php?request=http%3A%2F%2Fwww.airspeedparts.com%2Fgallery%2Falbums%2Fuserpics%2F10002%2Fnormal_jan10-28.jpg&hash=581fc2db42b2f846e822b0cba874fdfaa0dc80b0)
Thats all for now!
